New user here. It seems that it is not possible to change an entity's layer once the entity is created. Please confirm.
Hello,
Yes you can change an entities layer after you create the entity. Just go into the move command and you will see an option "ToLayer". Select the option and you will be put into the Layer Menu to pick a layer that you will want to move the entity to. You can also copy entities to different layers as well by going through the same process using Copy command. You have to have Layer Search ON if you are moving/copying entities when your Active Layer is different from the layer the entity to be moved/copied is on.
Users browsing this forum: No registered users and 62 guests
