#3052 by jmorgan6
Sun Jun 05, 2005 9:11 am
I am now using 11 almost exclusivly now
Little Problem
I use dual monitors with my left hand monitor as prime (drawing area here)
I have all of my tools on the right hand monitor with tool bars locked,
but they aint locked! Pesky devils wont stay put.
I also have the standard tool bar open and on the far left of the left hand monitor. ( primarily just want the undo/redo key)
Can I nail these suckers down?
Hep me.
John
#3086 by joshhuggins
Mon Jun 06, 2005 12:04 pm
From the Revision history file.
New features in version 11.05.00
14. A new option, Lock Toolbars, has been added to the View pull-down menu. If checked, all docked toolbars will be locked into their current position. Floating toolbars will remain undocked.
The following section can be added to DCADWIN.INI if you'd like to customize which regions (i.e., Top, Bottom, Left, and Right) of the program interface will become fixed when Lock Toolbars is enabled.
[Toolbars]
Locked=0
; Default value is 0. If set to a value of 1, all regions will lock/unlock. Top=2, Bottom=4, Left=8, 16=Right. If you only want the Top, Bottom, and Left regions to lock/unlock, set Locked to a value of 2+4+8 or 14.
