#3611 by Neil Blanchard
Wed Jun 22, 2005 11:17 am
Hello & welcome!
It's just about the same way it works in any version since v5! :o
Go to Settings\Edit Defs\Scales\Change, select a scale that you will no longer need for this file.
It then prompts you to enter the way it will show up in the menu -- so 1:40 or 3/32" or what ever.
It then needs you to enter the factor for the scale -- this is the results of the scale as an equation. So for example, 1/4" = 1'-0" or 1/4" = 12", then .25"/12"=0.02083333333333... The trick is to either use a feet/inch calculator or convert each side to the same unit, and then do the math.
If you did it right, then the new scale should be listed in the correct position. Also, if you have any MSP details set up, then this may affect the scales that you used for them -- worst case is you have to select each detail and Page Up/Down once and then right-click to place it back where it was.
#3613 by David A. Giesselman
Wed Jun 22, 2005 11:29 am
Neil Blanchard wrote:It then needs you to enter the factor for the scale -- this is the results of the scale as an equation. So for example, 1/4" = 1'-0" or 1/4" = 12", then .25"/12"=0.02083333333333... The trick is to either use a feet/inch calculator or convert each side to the same unit, and then do the math.
Just to follow-up on Neil instructions, you may also use DataCAD's online calculator to perform the above. Using Neil's above example of 1/4" = 1'-0", when DataCAD prompts you for the scale factor, enter the following:
Code: Select all=(1/4)/12
and DataCAD will calculate the result for you.
For Engineering scales such as 1:20, you would use:
Code: Select all=(1/20)/12
