#3685 by boofredlay
Fri Jun 24, 2005 2:38 pm
How do I match the properties of one line to the other. I thought I had it figured out but the two lines I am trying to match have different linetype scales. Hidden lines. One is showing at a large scale and the other is so small it is showing continuous unless you zoom in tight.
Also, how do you create a group out of a number of entities?
Thanks.
I am feeling frustrated now. :oops:
#3686 by Tony Blasio
Fri Jun 24, 2005 2:41 pm
The easiest way to have one entity Match another is to go to:
Change
Match
All
Pick the line you want to change, then pick the line you want to match.
To group entities go to:
The Edit Menu
F8 Group (pre v11 LinkEnt)
Then select the entities you want to be grouped.
Hope this helps.
#3687 by boofredlay
Fri Jun 24, 2005 2:53 pm
Thank you.
Now how do you offset a line perpendicular to itself a specified distance.
Thanks again. :D
#3688 by Tony Blasio
Fri Jun 24, 2005 3:03 pm
Go to the Geometry Menu
Select Offset
Make sure Dynamic is Off and select Perpendicular Distance
Enter your distance and then select the line you want to offset.
Hope this helps
#3690 by Neil Blanchard
Fri Jun 24, 2005 3:06 pm
Hello Fred:
Go to Geometry/Offset/Perpendicular. You can put this in the DcadWin.MCR file and use Alt-O as a shortcut:
O^Ä^20#^F3^F2^F2
...that is if you are using v11. It is possible in earlier versions -- but the macro is different.
#3733 by boofredlay
Mon Jun 27, 2005 2:00 pm
Thanks again for the help.
On the match command. I seem to have a problem putting an entity or group on another layer.
I do the change/match/all. However the layer does not match up with what I am selecting.
Help???
#3735 by Tony Blasio
Mon Jun 27, 2005 2:12 pm
Change doesn't affect Layers. You have to Move entities to a layer.
If you go to the Move Menu you will see a button labeld "To Layer".
Kinda like viewing Layers as locations or destinations, not attributes of entities.
#3736 by Dick Eades
Mon Jun 27, 2005 2:14 pm
To do that you will have to use the Move command, then select ToLayer.
There was a huge discussion about this long ago.
#3738 by boofredlay
Mon Jun 27, 2005 2:18 pm
Thanks guys.
Sorry I missed the discussion... I am new to DataCAD... very new.
