dennisnorton wrote:Thanks for you comments, Nick. Perhaps I am of the old school and don't know the present terminology in construction. I was taught that when a brick is laid end on end it is a soldier course and have used this detail for over 30 years. I have no idea what you comment "it isn't bonded" means.
You are almost certainly not as old as me, and this is probably just a cultural thing. If the brickies aren't laughing at you, and the walls haven't fallen down, don't worry about it.
My issue is this - if I have a wall 2'-7 5/8" long, the end bricks should be without vertical mortar joints. (The texture is 2'-8" long with one end joint) I have tried moving the origin points 3/8", but that didn't work. I have also played with the scaling factors of the materials, but that didn't work either. Maybe I am too much of a simpleton to understand what I am doing wrong.
What you have is a repetitive texture i.e. a few bricks several times, and I guess therein lies the problem. You can convert that into a single picture i.e. many bricks once, and sans the perpend at the end. It sounds like you have adequate control of origin and scale. You then stick that on the wall once. You can do this with much larger walls.
