I've done this before, but forgot how. You can change materials for everything in the door manager, except for the door. I have an older drawing that I have made the change, but can't figure out how I did it. Feeling a little stupid at the moment.
Roger, Thanks for the reply. I finally figured out how I did it before. Go to view>rendering>edit materials>pick wood door>uncheck apply texture>change rendered color to whatever color you want. I realize that this is only fine, if you want all the doors to be the same color, but I generally do.It is also easy to change back to wood grain. Bob
Ok, so in the Door Manager you had selected the Material "Wood Door" which sometime was defined by you. So yes, then you would need to go to the render material editor to change the definition of that "Wood Door" material.
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.01.02 (SE) http://www.RogerDonaldsonArchitect.com
