#60663 by Neil Blanchard
Wed Jun 12, 2013 1:43 pm
Greetings,
My 1-line trim keyboard shortcut is no longer working - I'm vaguely remembering a change in the way this works. My shortcut is supposed to toggle on Entity, and select the line and then pick the outside:
Code: Select allY^·^È^;^F9^F4^F1^$^$
//1-Line Trim
The menu is blank after I use it and the prompt says: click outside, but nothing happens. Am I missing something?
#60664 by Mark Toce
Wed Jun 12, 2013 1:55 pm
The status of the "Entity" toggle is controlled by a key in dcadwin.ini, so you would leave that step out of the command string.
Set the following in dcadwin.ini:
[General]
1LineTrim By Entity=TRUE
This will keep the "Entity" toggle always on.
The command string should then look like this:
Y^;^F9^F4^$^$^
Just make sure that your cursor is on the "outside" of the trim-to line when you press [Alt]+[y].
