#60723 by galenanderson
Sun Jun 16, 2013 3:16 pm
Is there any way to do this?
My firm uses schedules that are made up of a grid symbol and then a symbol for each entry that contains an attribute for each of the columns.
If i could tie each of those to a line of a csv document i could save a lot of time by making the schedule in excel but using datacad to lay it out graphically.
#60724 by Roger D
Sun Jun 16, 2013 6:32 pm
yes you can.
Look on page 350 of the manual where it discusses linking the symbol attribute to a database (.csv file).
Usuallly you pick the 1st item, and the rest get completed.
#60751 by Roger D
Wed Jun 19, 2013 8:07 am
What I have done is to open an standard excel file, Top row being headers/Titles of the columns to link to in DCAD.
Rows have the info you need.
Do a save as .csv so Dcad can read it.
In Dcad then, for the Symbol Attribute, you link to the file, and select the file and header/column.
In the sample below, the School Name is linked to the File , and the lookup field has the name
Symbol Attribute 1.png (40.98 KiB) Viewed 5684 times
Each line of the symbol below is linked to the same file, and when I pick the School Name, the other fields get populated.
Hope this helps.
Symbol Attribute 2.png (51.06 KiB) Viewed 5684 times
#60844 by galenanderson
Tue Jun 25, 2013 1:32 pm
I have a couple questions.
How do you make it so you only have to pick once for each symbol? I have been messing around a little but i have to pick for every attribute in the symbol.
Secondly, how do i change the path of the file that I am referencing. I want to make the symbol once, then populate it with different information in each drawing.
