Macro Sequence Question - Move Z, to Layer
Posted: Fri Aug 16, 2013 12:58 pm
I have one for the alias/toolbar gurus out there.
Most survey files we receive have the spot elevations, contours, and survey points at the actual z height. This is the first step in creating a site model, using any of the several tools available in DataCAD. Occasionally, the survey file will come in "flat" or without the correct z heights.
I am trying to automate the process of changing a series of spot elevation points to the actual z height.
In order to keep track of which points have been processed, I create a layer named "3d Spot Elevations" and turn it off.
The steps I am taking are:
1 2d Edit Menu - Move (F1)
2 Move Z (S3)
3 Enter new z height.
4. Return (to accept new height)
4 To Layer (S1)
5 Select 3d Spot Elevations
6. Select the entity, point, etc.
The processed entity will be on the new layer but not displayed so I know which items have been processed.
I am trying to write an alias that will automate the first 4 steps above, but I need the routine to pause while the z height is entered.
^;^F1^F3^$^S1^
Thanks in advance for any assistance on this.
2 Move Z (S3)
4 To Layer (S1)
^;^F1^F3^$^S1^
