#61333 by rogerra
Tue Aug 20, 2013 5:47 pm
I'm trying to have floor plan print lighter than the information on the plan (a background plan). I have set a pen (#4) in this case to print at 60%. It works ok when I print with the colored lines on.
But when I check "all black" I get a black an white pdf but the plan I wanted to print lighter is just black.
How can I solve the problem if anyone understands what I am saying?
#61336 by Nick Pyner
Tue Aug 20, 2013 7:37 pm
When you click all black you get all black 100%. You can get what you want by unclicking all black and mapping all colours individually to black with percentage variations as you require.
#61337 by Roger D
Tue Aug 20, 2013 7:38 pm
all black does mean all black, ignoring colors and density.
You might have to create a 2nd Pen Table that has the lines not colored.
#61346 by rogerra
Thu Aug 22, 2013 3:48 pm
Thanks. It doesn't work.
When I leave the pen designated light gray to print at 50%, in order for that to happen, I have to print the drawing in color. I don't want to pay for a color print just for a small background plan.
Maybe that's what I'll have to do.
Oh well.
#61348 by joshhuggins
Thu Aug 22, 2013 6:02 pm
You could map colors red thru cyan all to Pen 2 since they have the same settings which would free up pens 3-5 to be used for something else in the future.
#61352 by MtnArch
Thu Aug 22, 2013 11:13 pm
The other option would be to use a VERY thin pen setting - but be careful that whoever is printing the sheet for you doesn't use too low of a DPI setting. When I plot a sheet this way on my Canon inkjet plotter I get a really crisp sheet; when I send it out to my local repro company they have a laser that defaults to 300 DPI and I lose most of the thin line work. Josh recommended that I request that they use a higher DPI (600?) to force it to show everything correctly - I haven't yet but the next order will have that request!
#61354 by Neil Blanchard
Fri Aug 23, 2013 6:35 am
Hi Roger,
rogerra wrote:Thanks. It doesn't work.
Oh well.
You do not have to print any color if you don't want to. Map all the pens to grays (percentage density of black!) and black, like shown above, and there you go!
#61385 by rogerra
Wed Aug 28, 2013 4:00 pm
Thanks to all who responded. I have not had a chance to do any of the suggestions yet.
I'll let you know how they work when I do.
#61967 by Ted B
Mon Oct 21, 2013 2:27 am
If the base drawings is fairly straight-forwards, the other method I've seen is change the line-type of the screen-base to "dotted" and experiment a bit with lineweights and spacings to get a "screened" appearance.
Never have found a decent used for "dotted" lines anyway. In most architectural practices I've even worked-in over the last 30-years, conversationally that's what we called "dashed" lines . I still think "dotted" when in CAD I mean "dashed".
#62015 by Nick Pyner
Wed Oct 23, 2013 8:04 am
Yes it does, and no it isn't. Every colour you are using is black - in varying quantities. Indeed, the ability to print grey on a black-only printer is a reason for NOT getting a colour printer. In the pentable below, white and dark grey are used for light-grey and lighter grey lines and fills
