When I select the 3D Rotate command I am presented with the 2D rotate parameters when I am expecting the 3D rotate parameters. What could I be doing wrong?
This is what I am expecting to get when I select the 3D Rotate command
This is what I mostly get when I select the 3D Rotate command
Walter
DataCAD user since V3.6E
DataCAD V18 subscriber
