The layer order in the Layer Manager, and the Display/Layer Order both come into play with this. If the layer with the bitmap on it is at the top of the list in the LM (or at least above the layer with the text on it, and then if you have either Last or In Order selected in the Display/Layer Order menu - you should be good to go. If you have the text layer active (or any layer active other than the bitmap layer) then that can affect things.
If you have the text on the same layer at the bitmap - use the Move/To back on the bitmap, and that usually does it as well.
also might want to have Bitmaps to plot first set on in your pen table.
I placed the layer with the bitmap at the top of the LM list. However, it still comes in on top of my text. Why could this be?
You also have to set the Display/Layer Order to either Last or In Order. And you have to hit the U to recalculate the Display List.
Hey Neil,
Thanks for all your help! You pointed me in the right direction. I did exactly as you said and it worked fine. However, one small tip I learned is that after I did everything you suggested, I had to hit "U" after to update/refresh and it then displayed the drawing on the right layer.
Thanks again for all your help,
CADwk
CADwk
