#64103 by MtnArch
Wed May 21, 2014 9:45 pm
What is the command that Acad uses? Those of us that have/do use Acad/an Acad clone will be able to point the way once we know which one they use.
#64105 by CADwk
Thu May 22, 2014 10:11 am
I have not used AutoCAD in a while but I thought the command was called Array. In fact I think it had a copy array function where it would copy evenly spaced objects in a path by just dragging the mouse.
Hope this makes sense,
CADwk :o
#64106 by MtnArch
Thu May 22, 2014 10:42 am
Thanks - just wanted to make sure it wasn't a separate LISP routine!
You'll find it under Edit/Copy/Rect Array or Circ Array. Check out the manual to see exactly how to use each one - though they're pretty much what you've used with Acad.
