Weird o2c images
Posted: Fri Sep 30, 2016 4:12 pm
In the last two DCAD drawings I have started, when building a 3D model and viewing it with o2c, it is showing some very bad behavior. See the image below. The horizontal brown surface was a completely flat, solid, 2" thick slab. The round columns are solid, 3D vertical cylinders. As I rotate around the model, the hollowness of the various model components moves around and slides up and down the columns like a bug (the real kind, not the software kind). This happens with my office desktop computer and my home laptop so that would seem to rule out a dying video card. I can also export the file by dxf to SketchUp and it all shows up fine in SU.
Anyone having the same behavior? Any fix for this?
