Auto 3D keeps toggling off
Thu Dec 29, 2016 2:52 pm
by Bob Urbanek
Don't know what I did, but auto 3D toggles off when I use the insert door or window icon.
Re: Auto 3D keeps toggling off
Fri Dec 30, 2016 9:52 am
Hi Bob,
What version of DataCAD are you using, and are you working with smart walls? Are the icons you are using the standard ones?
Fri Dec 30, 2016 11:53 am
by MtnArch
Check in the Tools/Program Preferences dialog box, and under the "Menus" tab see if "View Dependent Editing" is checked?
Fri Dec 30, 2016 12:55 pm
by Bob Urbanek
Thanks for the replies. I am using V15. The boxes for view dependent editing weren't checked. Still didn't work right after I checked them, so I changed the settings back to defaults. That worked.
Recently, I had been having some eye strain problems, so I changed to a black background to see if it would help. I really prefer working with a white background, so after a while, I changed it back.I must have inadvertently
changed some other settings. (I guess) Thanks for the help.
Happy New Year, everyone.
