#77681 by stephen t.
Fri Feb 28, 2020 3:55 pm
Hello, long time since I've posted here and there's a lot of cobwebs around....I cannot remember how to create 3 line walls with the 'interior' line 4" and 8" from the two 'outside' lines. It keeps defaulting to be centered between the two outside line.
S
#77691 by dhs
Mon Mar 02, 2020 12:27 pm
I'm no expert on this, so only answering because nobody else has ....
If you are using 2d walls then I think the interior line will always be placed at the wall center. If you need it elsewhere then a workaround would be to use a 4 line wall with zero cavity width.
With smart walls (Auto 3D Option) then I think you need to create a wall type in the Wall Type Manager, and that allows you to specify the 'Offset from Previous Line' for the 2nd and 3rd lines.
Hope this is helpful.
