I use the same layer for several different drawings, however I need that same layer to print with dashed lines or differnt color on some layers and others I need them to print as drawn. Now I copy the layer and change the color, but then I have several versions that require multiplue sessions when changes are made.
Can I have one layer of several that can can be programed to print differently than drawn, while all the other files of that drawing print as drawn?
