This may be a simple thing, or it may be something that no one else uses, but I'm going to ask anyway.
I've begun using the "Save as bitmap" option to save line drawings as .png files for use in brochures and the like. The bitmap saved is always the screen extent and always exactly the same pixel size. Problem is, this bitmap pixels out fairly quickly when you try to enlarge it, and the given size only prints well at about 5-1/2" wide. Is there a way to change the size of the resulting bitmap???
Thanks!
Sionned
Thanks!
Sionned
