How can I put a window into a 3d arc wall?
I have made an arc wall, and converted it to a polygon, but it will not take a window using AEC.
Is there another way. The window is wider then the segments. So I can't use a slab and void it for the window opening.
Any ideas would be appreciated.
thanks p.
thanks p.
