Hello all,
I recently purchased a Dell E196FP 19" Inch Flat Panel LCD Monitor E193FP. I have plugged this into and booted up my laptop which has Windows XP. I can't get the screen to display correctly on my dell monitor. I checked the display properties dialogue box and there is a drop down menu which shows both my laptop monitor and dell monitor as Mobility monitor #1 & #2 respectively. It dosen't list the name or model of the monitor. My laptop displays as a wide screen format (more rectangular shaped screen) which has a different resolution then what I'm trying to display my dell flatscreen at. I want the dell to be at 1280x1074. I have these settings saved in the properties box for each monitor but the dell shows the screen being cropped off and the icons are way bigger than they should be. I checked the monitor screen adjustments but that wasn't it. My laptop says the driver being used is the correct one. I was thinking I still may need to find the dell driver and install it anyway. I'm not exactly sure how to install the driver when my laptop dosen't prompt me to.
Any help would be appreciated,
Sincerely,
Giuseppe Barberio
Sincerely,
Giuseppe Barberio
