To all,
I am currently with an Architectural firm with about 26 potential cad workstations. We currently have only 16 cad operators, none of whom know DataCAD. I am the only one of two in the office who has worked on DataCAD in the past. Everyone else has been on AutoCAD full version or AutoCAD LT.
My questions will be regarding a comparison of the two CAD programs; add-on software required and expected time to train employees.
With the USB dock key I see the possibility for employees to train at work and home. I feel that you should always try to advance your abilities even on your own time.
We have the full versions of AutoCAD 3.3 with added programs of Express Tools and DTI and AutoCAD 2005 and AutoCAD LT 2004. We also have an added program for AIA layer standards easier than AutoCAD’s and a structural program for drawing foundations, steel beams and steel stairs easier than AutoCAD’s that is used with the AutoCAD 3.3. Unfortunately no one knows or uses the full benefits of AutoCAD’s 3-D ability to complete building elevations and sections. We are still drawing in 2-D.
When I used DataCAD 5 years ago I questioned the boss why we were drawing elevations if DataCAD could do it for you. The answer I got was the files were too big. Now-a-days that should not be a problem.
Due to cost of upgrades for AutoCAD almost each year, we are considering DataCAD.
What kind of additional software would be required for DataCAD 11 that would be somewhat equivalent to what we currently use? We hope to teach CAD operators to use the 3-D drafting to save time on building elevations and sections with DataCAD.
How many of you use the 3-D ability to show building elevations and sections for construction drawings?
I was on DataCAD for 2-years, one year I trained myself (unemployed/self-employed) and a year with a firm using DataCAD. Then I changed firms and have been on AutoCAD ever since for about 10-years. I did not have a problem learning AutoCAD quickly. DataCAD I taught myself using the cassette tapes. I was drawing my first project in about a week helping another firm who also had DataCAD while at home.
How much time should be considered to train experienced AutoCAD operators to use DataCAD well?
Any input would be appreciated.
Codeman
Codeman
