#1392 by sentinel_spain
Wed Mar 30, 2005 10:41 am
Hi, all. I've many problems when I need to create a new wall style.
Yesterday, I'd need to create 25 cm of thickness. I drew it and close the program (and computer). Today, I need to build another wall of 15 cm.
But I've problems. The thickness and the height isn't correct. I supose that the solution is changing the scale of thickness, the space between lines. Everything is correct Everything is correct with regard to the yesterday parameters. I can't create a correct new wall style.
I also check the height in Z for if it was failing, but it was correct.
What is the correct way to execute the best manage of the commands?
Thanks!
#1395 by Neil Blanchard
Wed Mar 30, 2005 11:12 am
Hello:
You only need to push the = key and enter 15 to get a different wall thickness. To change the Z-Height or Z-Base of the wall, just push the Zz key and enter the values that you want.
Does this answer your question?
