Hi, all. I've many problems when I need to create a new wall style.
Yesterday, I'd need to create 25 cm of thickness. I drew it and close the program (and computer). Today, I need to build another wall of 15 cm.
But I've problems. The thickness and the height isn't correct. I supose that the solution is changing the scale of thickness, the space between lines. Everything is correct Everything is correct with regard to the yesterday parameters. I can't create a correct new wall style.
I also check the height in Z for if it was failing, but it was correct.
What is the correct way to execute the best manage of the commands?
Thanks!
Thanks!
