[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 384: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
forum.datacad.com • View topic - Video: Linework Over Rendering
PostPosted: Fri May 03, 2013 2:03 pm
by Mark F. Madura
Presentation at DBUG's 20th Anniversary Meeting: Linework Over Rendering
Note: Please feel free to start a discussion below this video by posting a reply.
Re: Video: Linework Over Rendering
PostPosted: Tue Mar 24, 2015 4:11 pm
by fsoliver
I tried this with a DataCAD plan but the o2C Interactive image didn't cut the walls at the windows and so you were looking at the tops of the wall. I tried to walk forward down into the plan to see if that would cut the walls at the center of the windows and that didn't work. I also did a clip cube in DataCAD at the windows and that didn't come through to o2c. Does anyone have any idea how this can be done in these programs?
PostPosted: Tue Mar 24, 2015 4:16 pm
by Mark F. Madura
The trick is to widen your cone of vision. In plan view, toggle to perspective viewing, increase your cone of vision, then toggle to parallel viewing.
Keep doing this until you get the clipping plane where you want it.
PostPosted: Mon Mar 18, 2024 7:39 am
by Clayton Taylor
To all & M+M,
Is this video link working for others ?
Its not working for me at my end ! :?
PostPosted: Tue Mar 19, 2024 11:09 am
by David Porter
Says the video link is not available.
