Just purchased 16 but it didn't copy my keyboard shortcuts I was using in 12. Is there an easy way to do that? Thanks
Sure, the DcadWin.MCR file from v12 can be copied to the v16 installation. (I'd rename the stock one in v16 something like Original-DcadWin.MCR to keep it.)
You may have to rewrite a couple of the shortcuts: Offset and Polyline Edit and maybe one or two others, need to be redone. If you have these or any others that stop working, then ask here and we can post the commands that work in v16.
