Sometimes when pdf's are made of hand drawn files the machine the x and y dimensions might be a little different that true scale coming out of the machine. Is there a way to compensate for this when bringing a jpeg into a drawing to trace over? I had one recently a jpeg (converted from the pdf) that was brought into a drawing to trace. Then when I enlarged the drawing based on the vertical "y" dimensions the "x" dimensions were way off.
It's been a while, but I think if you insert the image with the fixed ratio off you can stretch it or enlarge it by only one direction. I forget if this worked or not.
Thanks! - Josh
Yes, the enlargement factor can be set separately for X and Y (and Z) axis.
Thanks to all for this advice. Worked like a charm.
Users browsing this forum: No registered users and 115 guests
