#63791 by Neil Blanchard
Tue Apr 15, 2014 8:07 am
Hi,
If I create a Layer Set with the On Layers (2 layers are on) and I leave the Views and Details toggled on, it exports the entire drawing; not just the On Layers.
If I toggle off the Views and the Details, then it works as expected.
#63793 by Mark Toce
Tue Apr 15, 2014 8:59 am
Neil Blanchard wrote:Hi,
When "Views" and "Details" are included, all layers needed to recreate those views and details must be included in the layer set, even if they are currently turned off.
#63796 by Neil Blanchard
Tue Apr 15, 2014 12:04 pm
Okay, I was misunderstanding what those toggles were for, and I'm not sure why/when they would be used.
If I select On Layers, I was thinking that the Views would include the GTV for the current layers, and ditto for including any MSP details that consist of those layers.
#63799 by Mark Toce
Tue Apr 15, 2014 1:02 pm
Neil Blanchard wrote:Okay, I was misunderstanding what those toggles were for, and I'm not sure why/when they would be used.
Nope, sorry -- views and details are all or nothing in Layer Sets.
If you just want to save out the layers for one GoTo View, open the drawing and then select File/Purge. Click Layers/Deselect all, and then check the GoTo View you wish to save. DataCAD will automaticaly check the layers needed to recreate this view. Pick File/Save As AEC, and then save out a new file which contains just the one GoTo View and the associated layers.
#63812 by Neil Blanchard
Wed Apr 16, 2014 11:49 am
Thanks Mark - the Purge export was what I was thinking of, I think. I can make a new GTV after importing a Layer Set - this saves a lot of work when you need to add groups of similar layers several times in a file; to set up new details.
#63960 by Neil Blanchard
Tue May 06, 2014 1:21 pm
Another Layer Set issue: If I create a layer set that has a self reference on one of the layers - the self reference does not show up after I load the layer set into the same drawing it "came" from. I did an intermediate step of loading the layer set into a temporary drawing so I could rename the layers.
I'll just reinsert the self reference; no problem, but I figured I'd mention it.
Users browsing this forum: No registered users and 97 guests
