To all,
Over the last few years, I’ve seen a considerable downturn in the need to out put our plans to hard copy prints. Local authorities are quite happy to receive plans for Planning approval applications & the same for Building Regulation approvals, even our clients just request one or two prints. Builders also seem to accept plans in pdf format for tendering.
In this regard before you know it, your plans are all over the place & even unintended recipients who crib your hard work. What I’m ultimately driving at is, can DataCAD in the not too distant future incorporate a form of pdf protection, i.e. with options set to: view pdf’s only, view & print only & with a password option for these two settings. I was also wondering if others use some other form of software to do this...?? However to do this within DataCAD would be the ultimate choice for me.
Over & out,
Clayton.
Over & out,
Clayton.
Trotman & Taylor Architectural Consultants U.K.
