To all,
FILE SIZE REDUCTION WITH LOTS OF TEXT.
I’ve an A1 drawing with quite a lot of construction notes on one side of the drawing, this text is font type ARCWY2TX. When I save this plan out to pdf file format, it’s 9.977MB, quite a large file size that I didn’t anticipate. I turned the construction notes layer off & saved out again to pdf file format & the file size went down to 1.602MB.
So I was wondering if there are any tricks to reduce this file size down with the construction notes layer back on.??
Over & out,
Clayton.
Over & out,
Clayton.
Trotman & Taylor Architectural Consultants U.K.
