Few things you can do related to this.
Work around the missing Printer Popup:You can rename the new printer to the old printer name, setup another copy of the printer with old printer name or just leave the old printer installed even though it's missing so you don't get the little pop dialog box that tells you the printers missing. A setting to disable this message would be nice, chances are you will already know what printers are available to you right?
Non-descript Printer NamesWe ran into this same issue years back and decided going forward to just name our plotters and printer with non-descript names like 'Plotter' & 'LaserJet'. It works great, especially when different users print to different printers, so no matter which device their computer is set to print to for 'LaserJet', Datacad just knows the name and the windows printer settings handle sending the prints to the different printers. Yes it was a process for a year or so to update the current working files but once they were set everything going forward uses the non-descript names which makes it nice. We have swapped multiple printers since without a hiccup.
Use Printer Settings and/or Toolbar ButtonsAnother option once you have your workarounds for the old printer info is to setup saved Print settings. We created a drop down toolbar that loads all the settings for our most common printer settings that use the non-descript names (recommended) or the new printer name so we don't have to hassle with adjusting anything in the printer dialogs. If you do not have a printer installed with the name of the old printer, these will not work as they will get stuck on the little popup telling you the printer is missing. If you do have a printer setup with the old name, then you can use these DPS files and/or drop downs to quickly load all your new settings in one single click. The only thing you have to adjust once you have things setup to this point is if a new printer's paper size list is different than the old printers. You can easily just update the DPS files once when this happens.
Code: Select all[Prints]
DropDownCount=41
Hint=Single Prints
Icon=STD_Print
Hint00=Print Preview
Icon00=Preview
A00=^ë^:^S5^F1^
Hint01=Paper Sizes
Icon01=Paper Size
P01=rundll32 url.dll,FileProtocolHandler http://en.wikipedia.org/wiki/Paper_size#Architectural_sizes
Hint02=Load ADE Scales
Icon02=Scale ADE
A02=^:^F0^F4^F1^F7^ADE Scales.scl$^;^
Hint03=Load Architectual Scales
Icon03=Scale Architectural
A03=^:^F0^F4^F1^F7^Architectural.scl$^;^
Hint04=Load Engineering Scales
Icon04=Scale Engineering
A04=^:^F0^F4^F1^F7^Engineering.scl$^;^
// 05 Line Break
Hint06=8x11 Landscape 1"
Icon06=Print 8x11 Landscape
A06=^:^S5^S4^8x11 1 Landscape.dps$^F0^
Hint07=8x11 Landscape 1 1/2"
Icon07=Print 8x11 Landscape
A07=^:^S5^S4^8x11 1-1_2 Landscape.dps$^F0^
Hint08=8x11 Landscape 1/4"
Icon08=Print 8x11 Landscape
A08=^:^S5^S4^8x11 1_4 Landscape.dps$^F0^
Hint09=8x11 Landscape 3/16"
Icon09=Print 8x11 Landscape
A09=^:^S5^S4^8x11 3_16 Landscape.dps$^F0^
Hint10=8x11 Landscape 1/8"
Icon10=Print 8x11 Landscape
A10=^:^S5^S4^8x11 1_8 Landscape.dps$^F0^
// 11 Line Break
Hint12=8x11 Portrait 1"
Icon12=Print 8x11 Portrait
A12=^:^S5^S4^8x11 1 Portrait.dps$^F0^
Hint13=8x11 Portrait 1 1/2"
Icon13=Print 8x11 Portrait
A13=^:^S5^S4^8x11 1-1_2 Portrait.dps$^F0^
Hint14=8x11 Portrait 1/4"
Icon14=Print 8x11 Portrait
A14=^:^S5^S4^8x11 1_4 Portrait.dps$^F0^
Hint15=8x11 Portrait 3/16"
Icon15=Print 8x11 Portrait
A15=^:^S5^S4^8x11 3_16 Portrait.dps$^F0^
Hint16=8x11 Portrait 1/8"
Icon16=Print 8x11 Portrait
A16=^:^S5^S4^8x11 1_8 Portrait.dps$^F0^
// 17 Line Break
Hint18=11x17 Landscape 1/4"
Icon18=Print 11x17 Landscape
A18=^:^S5^S4^11x17 1_4 Landscape.dps$^F0^
Hint19=11x17 Landscape 3/16"
Icon19=Print 11x17 Landscape
A19=^:^S5^S4^11x17 3_16 Landscape.dps$^F0^
Hint20=11x17 Landscape 1/8"
Icon20=Print 11x17 Landscape
A20=^:^S5^S4^11x17 1_8 Landscape.dps$^F0^
// 21 Line Break
Hint22=11x17 Portrait 1/4"
Icon22=Print 11x17 Portrait
A22=^:^S5^S4^11x17 1_4 Portrait.dps$^F0^
Hint23=11x17 Portrait 3/16"
Icon23=Print 11x17 Portrait
A23=^:^S5^S4^11x17 3_16 Portrait.dps$^F0^
Hint24=11x17 Portrait 1/8"
Icon24=Print 11x17 Portrait
A24=^:^S5^S4^11x17 1_8 Portrait.dps$^F0^
// 25 Line Break
Hint26=24x36 Plot 1/4"
Icon26=Print 24x36
A26=^:^S5^S4^24x36 1_4.dps$^F0^
Hint27=24x36 Plot 3/16"
Icon27=Print 24x36
A27=^:^S5^S4^24x36 3_16.dps$^F0^
Hint28=24x36 Plot 1/8"
Icon28=Print 24x36
A28=^:^S5^S4^24x36 1_8.dps$^F0^
// 29 Line Break
Hint30=24x36 Check Plot 1/4"
Icon30=Print 24x36 Check
A30=^:^S5^S4^24x36 1_4 11x17.dps$^F0^
Hint31=24x36 Check Plot 3/16"
Icon31=Print 24x36 Check
A31=^:^S5^S4^24x36 3_16 11x17.dps$^F0^
Hint32=24x36 Check Plot 1/8"
Icon32=Print 24x36 Check
A32=^:^S5^S4^24x36 1_8 11x17.dps$^F0^
// 33 Line Break
Hint34=30x42 Plot 1/4"
Icon34=Print 30x42
A34=^:^S5^S4^30x42 1_4.dps$^F0^
Hint35=30x42 Plot 3/16"
Icon35=Print 30x42
A35=^:^S5^S4^30x42 3_16.dps$^F0^
Hint36=30x42 Plot 1/8"
Icon36=Print 30x42
A36=^:^S5^S4^30x42 1_8.dps$^F0^
// 37 Line Break
Hint38=30x42 Check Plot 1/4"
Icon38=Print 30x42 Check
A38=^:^S5^S4^30x42 1_4 11x17.dps$^F0^
Hint39=30x42 Check Plot 3/16"
Icon39=Print 30x42 Check
A39=^:^S5^S4^30x42 3_16 11x17.dps$^F0^
Hint40=30x42 Check Plot 1/8"
Icon40=Print 30x42 Check
A40=^:^S5^S4^30x42 1_8 11x17.dps$^F0^
