forum.datacad.com • View topic - Move to Layer Changes Line Color
PostPosted: Wed Jun 29, 2016 3:06 pm
by Aaron Ben-Avraham
Hi All.
I'm, for now, still using DataCAD 16. I have a file from someone who is using Datacad 17 and whenever I move entities to a new layer the lines change to the layer color. I know this is a feature that is in newer versions, however I don't want the entities to change color. I'm assuming this is a BUG because AFAIK Datacad 16 doesn't have this ability - unless I've missed something...
Is there a way that I can stop this from happening (INI setting?)?? I don't see any menu settings in 16 to turn this on and off ...
Aaron
Re: Move to Layer Changes Line Color
PostPosted: Wed Jun 29, 2016 3:16 pm
by David A. Giesselman
You don't see this toggle in the To Layer menu?
PostPosted: Wed Jun 29, 2016 3:30 pm
Hi Dave,
No, I don't have that as an option.
I'm using version 16.04.01.03 (PE)
PostPosted: Wed Jun 29, 2016 3:42 pm
Here is a screenshot (hopefully - this is the first time I've ever needed to post a screenshot) which is in OneDrive - No idea if this will work!
Edit: I did something wrong as it did not work. How do you post a screenshot?
Here is a link (I hope)
https://1drv.ms/f/s!AoETR3uWaw33lz9ef7n7LOmUBhGa
PostPosted: Wed Jun 29, 2016 3:55 pm
Don't know if it makes a difference but I am also using Window10
PostPosted: Wed Jun 29, 2016 4:04 pm
:oops:
Never Mind! After going back and looking at your image I realized I was looking at the wrong menu! I never realized that this was in DataCAD 16!
:oops: :oops: :oops:
:lol: :lol: :lol:
