#66337 by Neil Blanchard
Fri May 01, 2015 2:28 pm
Hi,
I just noticed that the Update GTV button in the Layer Manager doesn't work with the GTV Link. I already had GTV Link toggled on, and when I toggled on the XRef layer, and change the layers that er on in the RFM, and then Update the GTV using the LM button, it doesn't work. If I use the GTV menu Update View button, it does work.
#66339 by joshhuggins
Fri May 01, 2015 2:31 pm
The Update GTV button in the Layer Manager only updates what actual layers are turned on/off for a GTV. It does not record any changes to things like xrefs with GTV Link layer changes, highlight settings, clip cubes, etc.
