Use this forum to ask questions about DataCAD 17 and DataCAD LT 17.
#66406 by GARY247
Thu May 14, 2015 3:08 pm
I had hotkeys that were all set up in versions 15 and 16. I tried to reused them but the file appears written to be totally different. I tried coping the file over but version 17 will not use them. How do I fix the hotkeys to work the way I had them as none of the new ones are of any use to me.
Gary Stahl
Holmes King Kallquist
575 North Salina Street
Syracuse, New York
#66412 by GARY247
Thu May 14, 2015 4:13 pm
Why aren't these working or how do I apply these to version 17? I also have my cap lock on all the time when I am using DCAD.
A^·^È;^S5^¸^É
B^:^F4
C^·^S5^S6^S1
D^:^È^;^F1^F1^S1^
E^·^È^;^F6^¸^É
F^·^170#^$^
G^·^È^:^F6^¸^É
H^·^È:^F9^¸^É
I^·^È^;^S1^¸^É
J^·^È^;^F9^F5^¸^É
K^·^È^;^F8^¸^É
L^·^È^;^S7^¸^É
M^·^È^;^F4^¸^É
N:^S6^F1
O^·^È^:^S3^F8^S0^¸^É
P^·^È^:^S5^¸^É
Q^·^È^;^S6^¸^É
R^·^È^;^S4^¸^É
S^·^È^;^S2^¸^É
T^.^È^;^S7
U^·^È^;^S8^S0^¸^É
V^·^È^;^S8^S9^¸^É
W^·^È^;^S6^S2^¸^É
X^:^F0^F2
Y:^S7
Z^·^È^;^F0^S8^S2^¸^É
#66413 by joshhuggins
Thu May 14, 2015 5:32 pm
There are several syntax typos I see. Make sure to close the string with a ^ Try making these corrections and see how things go.
A^·^È^;^S5^¸^É^
B^:^F4^
C^·^S5^S6^S1^
//Alt+C is missing it's start point. ( ideally ; or : ) As is, you would have to make sure you are in a specific menu that would start Alt+C with ^S5^S6^
D^:^È^;^F1^F1^S1^
E^·^È^;^F6^¸^É^
F^·^170#^$^
G^·^È^:^F6^¸^É^
H^·^È:^F9^¸^É^
I^·^È^;^S1^¸^É^
J^·^È^;^F9^F5^¸^É^
K^·^È^;^F8^¸^É^
L^·^È^;^S7^¸^É^
M^·^È^;^F4^¸^É^
N^:^S6^F1^
P^·^È^:^S5^¸^É^
Q^·^È^;^S6^¸^É^
R^·^È^;^S4^¸^É^
S^·^È^;^S2^¸^É^
T^.^È^;^S7^
U^·^È^;^S8^S0^¸^É^
V^·^È^;^S8^S9^¸^É^
W^·^È^;^S6^S2^¸^É^
X^:^F0^F2^
Y^:^S7^
Z^·^È^;^F0^S8^S2^¸^É^
Also not having comments in the file makes it a bit hard to know what you intended goal is. You can add comment lines to the file by putting // in front of the comments.
Example:
Code: Select allB^:^F4^
// Templates
#66414 by GARY247
Thu May 14, 2015 8:01 pm
What meaning do the numbers have when there are no key functions? There seem to be a lot of these. If this worked for version 15 and 16 how come it does not work for 17?
#66420 by GARY247
Fri May 15, 2015 9:43 am
I found out what the problem was. The person that loaded version17 changed my support file location to the server. I could not understand why it was not recognizing the mcr file that I put in there in then it clicked. Once I changed it back to my "C" drive it worked. Thanks for your help.
