MCR VALUES
Thu May 14, 2015 3:08 pm
by GARY247
I had hotkeys that were all set up in versions 15 and 16. I tried to reused them but the file appears written to be totally different. I tried coping the file over but version 17 will not use them. How do I fix the hotkeys to work the way I had them as none of the new ones are of any use to me.
Gary Stahl
Holmes King Kallquist
575 North Salina Street
Syracuse, New York
Re: MCR VALUES
Thu May 14, 2015 3:44 pm
The MCR file has not changed format. The file should be located in the Support Files folder. Can you post your MCR file contents and which shortcut keys are not working?
VERSION 16 MCR VALUES
Thu May 14, 2015 4:13 pm
by GARY247
Why aren't these working or how do I apply these to version 17? I also have my cap lock on all the time when I am using DCAD.
A^·^È;^S5^¸^É
B^:^F4
C^·^S5^S6^S1
D^:^È^;^F1^F1^S1^
E^·^È^;^F6^¸^É
F^·^170#^$^
G^·^È^:^F6^¸^É
H^·^È:^F9^¸^É
I^·^È^;^S1^¸^É
J^·^È^;^F9^F5^¸^É
K^·^È^;^F8^¸^É
L^·^È^;^S7^¸^É
M^·^È^;^F4^¸^É
N:^S6^F1
O^·^È^:^S3^F8^S0^¸^É
P^·^È^:^S5^¸^É
Q^·^È^;^S6^¸^É
R^·^È^;^S4^¸^É
S^·^È^;^S2^¸^É
T^.^È^;^S7
U^·^È^;^S8^S0^¸^É
V^·^È^;^S8^S9^¸^É
W^·^È^;^S6^S2^¸^É
X^:^F0^F2
Y:^S7
Z^·^È^;^F0^S8^S2^¸^É
Re: MCR VALUES
Thu May 14, 2015 5:32 pm
Re: MCR VALUES
Thu May 14, 2015 8:01 pm
by GARY247
What meaning do the numbers have when there are no key functions? There seem to be a lot of these. If this worked for version 15 and 16 how come it does not work for 17?
Re: MCR VALUES
Thu May 14, 2015 9:05 pm
Re: MCR VALUES
Fri May 15, 2015 9:43 am
by GARY247
I found out what the problem was. The person that loaded version17 changed my support file location to the server. I could not understand why it was not recognizing the mcr file that I put in there in then it clicked. Once I changed it back to my "C" drive it worked. Thanks for your help.
