Layer Manager window lock up DataCad 17 in Windows 10
Thu Aug 20, 2015 6:38 pm
by acormond
I just updated my system to Windows 10. When I bring up DataCad 17 and try to bring up the Layers Manager the whole of DataCad locks up. I have to kill it with the Task Manager. This happens when editing an old drawing or when creating a new one. It would take me a very long time to re-install Windows 7 so what do I do? (By the way, if there were a 64 bit version of DataCad which ran on Linux that would be wonderful.)
Re: Layer Manager window lock up DataCad 17 in Windows 10
Thu Aug 20, 2015 6:50 pm
by David A. Giesselman
It sounds as though the Layer Manager is opening off-screen. Try holding down the [Ctrl]+[Shift] keys when you open then Layer Manager. This will force it to open in its default position.
Regards,
Thu Aug 20, 2015 11:55 pm
by tigere
@ David A. Giesselman
What does that mean: "opening off screen" ? And if you default it as you suggest does that resolve the problem for the future ?
TIA
Roger Pingree
Fri Aug 21, 2015 8:16 am
The dialog box is opening, but the computer "thinks" it is in a position on the desktop where you cannot actually see it. If you have had a computer set up with two monitors, and then you run it with just one, or you changed the resolution of one or both of the monitors, then this can cause this to happen.
Fri Aug 21, 2015 12:22 pm
by acormond
What? Now it works! It didn't many times. Mark must have intervened from afar.
Fri Aug 21, 2015 12:25 pm
by acormond
Oh. The issue was with two monitors. Thanks for the help.
