Print setup hangs
PostPosted: Fri Oct 02, 2015 6:16 pm
by acormond
Went I try to set up my printer in DataCad 17 on Windows 10 it just hangs no matter what I do. Help please.
Re: Print setup hangs
PostPosted: Fri Oct 02, 2015 6:28 pm
Try using [Ctrl] + [Shift] + [C] to clear the print settings first before opening the print menus.
PostPosted: Fri Oct 02, 2015 7:17 pm
by David A. Giesselman
Good call Josh! But if that doesn't work, the dialog may just be opening off-screen. I'm assuming you recently upgraded to Win10, yes? With that, your display settings may have changed. Try holding down the [Ctrl]+[Shift] keys when you invoke the setup dialog. That should force it to open in its default position.
PostPosted: Fri Oct 02, 2015 9:51 pm
by MtnArch
Dave -
AND you know this about Win 10 BECAUSE ...?
(You haven't left your beloved XP, have you?!?!) :twisted:
