CLEAN UP
PostPosted: Mon Oct 26, 2015 12:44 pm
by GARY247
Is there any way to change the clean up one line trim function so it stays off unless you click F1(entity) to turn it on? I looked in datacad.ini but did not see anything.
Re: CLEAN UP
PostPosted: Mon Oct 26, 2015 12:54 pm
by David A. Giesselman
Look in the [General] section of the INI file for the following key:
1LineTrim By Entity=TRUE
  • If present and TRUE, Entity will always be On.
  • If present and FALSE, Entity will always be Off.
  • If not present, Entity will remember its previous state
Re: CLEAN UP
PostPosted: Mon Oct 26, 2015 1:13 pm
by GARY247
