tangent mode and direction distance
Thu Nov 19, 2015 7:48 pm
by rlmorton
Why when in tangent mode and I enter a distance it sends me off in a totally different direction than I had drawn the line? Do not have this problem when it is not in the tangent mode- driving me crazy
Re: tangent mode and direction distance
Fri Nov 20, 2015 1:27 am
by MtnArch
You need to make sure that you have already rotated your cursor to match what you are trying to do in Tangents. Unfortunately DC doesn't change the cursor rotation to match tangents. Make sure you request it as a WishList for the next beta/and/or release candidate!
Fri Nov 20, 2015 10:53 am
by rlmorton
MtnArch wrote:You need to make sure that you have already rotated your cursor to match what you are trying to do in Tangents. Unfortunately DC doesn't change the cursor rotation to match tangents. Make sure you request it as a WishList for the next beta/and/or release candidate!
I am still confused- have been using tangents and directions forever and never ran into this problem - when you are in tangent mode the cursor automatically points in the new tangent direction.
Fri Nov 20, 2015 2:02 pm
by MtnArch
You might check the start angle in your grid settings.
Fri Nov 20, 2015 4:43 pm
by rlmorton
I tried that - no luck - the off set angle is not consistent - meaning if I change the tangent it also changes the offset - I can't seem to find anything that is consistent or logical with this problem - only thing I can think of is that it is related to the dwg file that was imported.
Fri Nov 20, 2015 6:36 pm
by Mark Bell
Hi Rlmorton,
We've had this on and off since v5 believe it or not. It's a hard one to pin down and the importing of DWG files is a likely candidate for the crosshair not going where you direct it to. If you turn off ortho and look at the coordinate readout you can generally get the crosshair to go in the right direction by entering the +/- X and Y values (most of us here use Rel. Cart.). Changing the grid angle settings has no effect. In most instances purging the file will correct this.
Mon Nov 23, 2015 9:10 am
I use Direction / Distance, and when I use Tangents to tilt the cursor, I like to toggle on Show X and Y in the Grids menu. This puts an X and Y next to the cursor. You can also use Show Zero, if you prefer.
This makes it clear what direction is what when the cursor is tilted.
