#67901 by joeferguson
Wed Dec 23, 2015 5:16 pm
I am using goto views for the first time in about three years, so this is my first attempt in DC 17.
I invoke the gtv menu and press "Add View". The program asks me to input a name.
I type a name "2FLOOR" and press Enter and poof! my work vanishes and I am left facing a gray DataCAD screen (as if I am just starting the program.)
I must be insane because I repeated the same process six times, expecting a different result.
I pulled up an old file created in DC 11 where I successfully used gtv's. Same result -- file vanishes.
Any ideas on what just happened?
joe
#67904 by joeferguson
Wed Dec 23, 2015 7:39 pm
Well I reinstalled and the problem went away.
The following from DataCAD's revision list explains it better:
Important information about DataCAD 17 and Windows 10 'November Update':
Coincident with the November update of Windows 10 (OS Build: 10586, Version 1511), DataCAD users began reporting unexpected drawing closures when performing certain menu actions. In particular, the drawing would close when using the [F1] key to select On/Off from the Layer menu. However, selecting On/Off with the mouse would not cause the error. In other parts of the program such as the GoTo View menu, adding a view, then pressing [Enter] would also cause the drawing to close.
DataCAD 17.04.01 addresses these problems and we highly-encourage you to update DataCAD to the latest version if you are running it on Windows 10.
#67905 by MtnArch
Wed Dec 23, 2015 9:50 pm
Gotta luv MS - "Sorry we screwed you up ... but look at all we CHANGED!!!"
:roll:
#68072 by shkoehle
Wed Jan 20, 2016 2:01 pm
So I am using Datacad 14.03.02.08 and am experiencing the Go to view issue.
Has anyone tried reinstalling 14? compatibility mode?
Any other options?
DATACAD: Is there a simple fix or patch (at a cost less than DCAD 18 upgrade?)
I have 3 HP Z210 towers all running Windows 10 and DCAD 14. Only 2 of them have the problem. The other works fine.
I am working to narrow down the issue. My guess is a configuration issue but it could be in Windows 10 or DCAD 14...?
Any help is appreciated.
#68318 by abanov
Sat Feb 27, 2016 12:11 pm
I have had the problem with unexpected closures with layer picking after installing Windows 10. I was told to get the update--which I had just done. Now I realize that my Datacad will not update properly. It says there is an update available 17.04.02.02, but after doing the update, my version is still 17.02.00.09. Help?
#68320 by Roger D
Sat Feb 27, 2016 12:15 pm
2 options:
Run Datacad as administrator, then check get the update
Good to Datacad Product updates page, manually download the update and run it.
#68321 by abanov
Sat Feb 27, 2016 12:35 pm
Thanks. I updated it manually and it appears to be correct now. It isn't crashing when I pick the layers. Is there a setting in Win 10 that I need to change to allow it to update automatically?
#68322 by Roger D
Sat Feb 27, 2016 12:45 pm
Not that I know of, I'm on 10 with my laptop, desktop is still 7.
#68393 by Keithster
Tue Mar 08, 2016 3:32 pm
Thanks for the question and the helpful answers. I succumbed to the pressure to update to Windows 10, and immediately had crashing problems. I thought I had updated but manually updating worked. I grateful for this forum.
Keith
Users browsing this forum: No registered users and 9 guests
