ASSOCIATIVE DIMENSION SUFFIX
Mon Jan 18, 2016 9:48 am
by GARY247
Is there any way to have it so the associative dimension properties suffix is always on? I looked in the INI file but did not see anything.
Re: ASSOCIATIVE DIMENSION SUFFIX
Mon Jan 18, 2016 9:55 am
Under Dim Style, S9 Suffix, turn it on, it will ask for the text to use.
at least in v18 it's there.
Mon Jan 18, 2016 11:03 am
by GARY247
Not seeing it in V17. Must be something they added. Thanks for your response.
Mon Jan 18, 2016 11:32 am
just reactived my v17.04.01.03 and it is there.
Dimensions/Linear/Dim.Style/Suffix
Do you have the latest update?
This is why I have versions X3 to v18 on this machine (soon to be semi-retired) so I can answer questions to other local users who are on different versions.
Mon Jan 18, 2016 3:50 pm
by GARY247
Made sure I had latest update but still cannot find it in the dcadwin.ini file. What category is it under? I did not see anything that related to dimensioning.
Mon Jan 18, 2016 3:54 pm
Not in the .ini file, in the program under the Dimension Menu, Dim Style, Suffix
Mon Jan 18, 2016 5:02 pm
by GARY247
Got it. Thank you.
