Is there a toolbar that would open up directly to the editing of a clip cube or a fast key setup/hotkey?
I am assuming that this works only if you are using the 3d option. I tried this but it picks every xref in the drawing, blinks 4 times and then dumps out so I am assuming that this will not work in 2d. I was trying to find a quicker way than hitting control and right mouse button to get a menu and I see no way of getting to clip cubes in either of the 2d menus other than going to insert, reference file management and clicking on clip cubes. I tried this E^·^S0^S8^S9^S7^F0^F8^S0^S8^ but it won't return me to the 2d menu after the edit like going to the insert option. It also only gets me there if I am in the utility menu with alt E.
Try this in your toolbar:
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
I have no idea of how to accomplish that Dave.
I wrote that using v18, there might be an issue with you using v17.
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
I use mostly hotkeys that I have set up for my left hand. The only tool bars that I use are navigation, projection, status, symbol browser, coordinates, viewer and standard. I modified a hotkey to this E^·^S0^S8^S9^S7^F0^ which seems to work except I have to figure out how to get it back to the 2d menu automatically. I would still like to know what you were talking about previously. I do have 18 on my machine but have not used it yet as I am on a deadline and do not have the time to mess with setting up the program.
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
