#70156 by yvboa
Mon Nov 07, 2016 4:39 pm
How do I remove the lines around an image that I have inserted into a DataCad drawing?
#70157 by Roger D
Mon Nov 07, 2016 4:45 pm
Right click on the image, Pick the Polyline Properties at the top, and change the "Show Fill Outline" to No.
When inserting the image, the menu will change and give you that option just before you define the rectangle.
#70158 by yvboa
Mon Nov 07, 2016 5:06 pm
Thank you Roger. One more question. Is there a way to not make it a big white box? I can print it fine but on the screen it blocks out the line work behind it.
#70159 by Roger D
Mon Nov 07, 2016 6:06 pm
put it on a layer that is earlier in the list, and under display set Layer Order to be either In Order or last, which have the line work layer being the active layer.
#70160 by yvboa
Mon Nov 07, 2016 7:13 pm
only working partly. Is there no way to make the white of the box transparent like you can do in Microsoft Word?
