inserting images
PostPosted: Mon Nov 07, 2016 4:39 pm
by yvboa
How do I remove the lines around an image that I have inserted into a DataCad drawing?
Re: inserting images
PostPosted: Mon Nov 07, 2016 4:45 pm
Right click on the image, Pick the Polyline Properties at the top, and change the "Show Fill Outline" to No.
When inserting the image, the menu will change and give you that option just before you define the rectangle.
PostPosted: Mon Nov 07, 2016 5:06 pm
by yvboa
Thank you Roger. One more question. Is there a way to not make it a big white box? I can print it fine but on the screen it blocks out the line work behind it.
PostPosted: Mon Nov 07, 2016 6:06 pm
put it on a layer that is earlier in the list, and under display set Layer Order to be either In Order or last, which have the line work layer being the active layer.
PostPosted: Mon Nov 07, 2016 7:13 pm
by yvboa
only working partly. Is there no way to make the white of the box transparent like you can do in Microsoft Word?
PostPosted: Tue Nov 08, 2016 8:47 am
If it is white, it won't show up on the paper.
