Layer Menu
PostPosted: Wed Nov 16, 2016 1:10 pm
by Robert Scott
Recently I've run into an issues that appears now to be across all Datacad files:
If I initiate the Layer menu either by L or navigating directly I'm kicked out of the file.
I can use the Layer manager to turn layers off and on.
Any thoughts?
Robert
Re: Layer Menu
PostPosted: Wed Nov 16, 2016 1:25 pm
Reboot?
Re: Layer Menu
PostPosted: Wed Nov 16, 2016 1:40 pm
by David A. Giesselman
Robert,
Exit DataCAD, Right-Click on your DataCAD icon, select Run as Administrator and perform a Check for Update....
It sounds like MS gifted you a Windows update when you weren't looking.
Re: Layer Menu
PostPosted: Wed Nov 16, 2016 2:08 pm
by Robert Scott
David A. Giesselman wrote:Robert,
Thanks David,
That did the trick...
Robert
