We need King Brick Herringbone for DataCAD17 do you know where I can save this to upload in the hatch manager? It would be ideal to be able to create our own hatches. Any help is much apprectiated!
What are the dimensions of this brick? Do you have the hatch pattern of a standard brick herringbone? If so, you may be able to save a copy, and edit the numbers to get the pattern you need, with some trial and error.
You might try this from Josh Huggins' web site.
http://joshhuggins.com/product/unilock-paver-hatch/
Here is a pattern that I wrote up today. Hopefully, it works for you.
It is a 3X10 layout. Use at a scale of 1 and at a 45 degree angle for the VVV typical for Herringbone.
Hmmm. I'm not seeing the file as an attachment. I get a message that the dhp extension is not allowed. Since it's not accessible, please contact me at orwoody@gmail.com and I'll send it to you directly.
Good luck and have a Merry Christmas.
Woody
Woody
I posted that code per Neil's suggestion. I was a bit hesitant to do that since the file is a large one for a straight text list.
Herringbone is one of those patterns where there are a lot of entities in the pattern between any two similar entities and especially so for king size brick.
Woody
Woody
Thanks, Woody! Life just got easier!
Users browsing this forum: No registered users and 79 guests
