Before Ver.18, my files just had the 4-5 basic embedded linetypes in the sidebar Line Type Menu, and I could load addl. external linetypes as I need them, or delete the addl. linetypes. When I changed-over the Ver.18, now the Line Type sidebar menu is full of unneeded embedded linetypes that I don't need in every drawing, and I don't see a method of either deleting them -- or not preloading them in the first-place. For 99% of the time, I only need solid, dashed, dot-dash, centerline and propline. The rest are duplicated in the external linetypes if-needed.
This occurs in both "new" files, and legacy files that I'm either continuing to use or use as master template files for new projects.
It's probably a simple fix. It's just not obvious.
