I have tried multiple settings the ArcFactor in the Display menu, but I cannot find a setting that will display small and large circles or arcs smooth. For instance, I can set the arcfactor to 4 and door swings will display smooth, but small circles (like you might use for a door number mark) will not display or print as a circle at all; it displays/prints as a triangle. Then if I increase the arcfactor to say 10, the door swing arc is till ok, but the smaller circle just doesn't display at all. Then if I decrease the arc factor to .5 the smaller circles display smooth, but larger circles/arcs are not smooth at all.
See attached picture for the monitor I'm using.
And one more time.....THANKS IN ADVANCE FOR YOUR HELP!
Brady Moore
