#67712 by rhassoc
Mon Dec 07, 2015 8:53 pm
When Batch Plotting sheets with a locked layer containing a XRef, I am getting a warning dialog box stating that the "GoTo View was unable to be added/updated for these XRefs".
I am not changing the GoTo Views, only plotting. Does not happen when doing a quick layout of the same GoTo View and then Print/Plot.
Easy to just hit the Ok button but annoying.
#67729 by joshhuggins
Tue Dec 08, 2015 2:42 pm
Not 100% sure, but I think this happens when an xref is set to use GTV link, but it can't change it's settings for the remembered link because the layer that the xref is on is locked.
#67733 by David A. Giesselman
Tue Dec 08, 2015 3:39 pm
Try adding/modifying the following key in [XREFS] section of the INI file:
Always Update GTV Links=TRUE
#67738 by rhassoc
Tue Dec 08, 2015 5:49 pm
Changing the value to "TRUE" worked.
Thanks for the quick response, now on to learning more new features.
