[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 384: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
forum.datacad.com • View topic - Xref on locked layer Warning
PostPosted: Mon Dec 07, 2015 8:53 pm
by rhassoc
When Batch Plotting sheets with a locked layer containing a XRef, I am getting a warning dialog box stating that the "GoTo View was unable to be added/updated for these XRefs".
I am not changing the GoTo Views, only plotting. Does not happen when doing a quick layout of the same GoTo View and then Print/Plot.
Easy to just hit the Ok button but annoying.
Re: Xref on locked layer Warning
PostPosted: Tue Dec 08, 2015 2:42 pm
Not 100% sure, but I think this happens when an xref is set to use GTV link, but it can't change it's settings for the remembered link because the layer that the xref is on is locked.
PostPosted: Tue Dec 08, 2015 3:39 pm
by David A. Giesselman
Try adding/modifying the following key in [XREFS] section of the INI file:
PostPosted: Tue Dec 08, 2015 5:49 pm
by rhassoc
Changing the value to "TRUE" worked.
Thanks for the quick response, now on to learning more new features.
