#68513 by nwilkey
Sun Apr 03, 2016 8:50 pm
Is there a way to set my preference for a Big Cursor. I have an employee that likes the little cursor. I always have to change to big if he has been in the drawing. I'm about ready to make him always change it back but was hoping there was a way to set it for my pc. I did spend time looking on the boards but after 30 min. I stopped.
Thanks.
#68516 by joshhuggins
Sun Apr 03, 2016 10:18 pm
I just use Shift+Plus/Equal key which toggles the cursor.
#68520 by Roger D
Mon Apr 04, 2016 7:25 am
and I use the plus key on the numkey area, saves the Shift button.
#68522 by joshhuggins
Mon Apr 04, 2016 1:20 pm
Roger D wrote:and I use the plus key on the numkey area, saves the Shift button.
Well what do ya know? I got my learnin' for the week! Thanks Roger!
#68523 by nwilkey
Mon Apr 04, 2016 2:58 pm
Thank you all. That will help.
Would still like to have it changed as a setting at the ini level. Like being able to add the backwards area to do a select all without using crossing.
Is that available?
#68525 by joshhuggins
Mon Apr 04, 2016 3:13 pm
Josh wrote:Yup! Look under the General section of the dcadwin.ini file. You can find most of the ini options on the DCADWIN.INI Undocumented page.
Code: Select all[General]
Automatic Crossing Selection=FALSE
; If TRUE, area selection from right to left will imply crossing.
With the latest v18 update, this is now found in the Program Prefs, on the new Drawing tab.
#68919 by nwilkey
Thu May 19, 2016 1:42 pm
Thank you! Oft times these little things make life so much easier. :D
